Cannot control both switches in a GE ZW4105 2-switch plug in outlet
I can add this GE unit but Smartthings will not control both switches. The panel/card/screen for the unit has on/off, which controls switch 1, but no way to control switch 2. Did I just spenc $40 on something that Smartthings does not support?
Found this in Amazon questions
By “web console”, he means the IDE
https://account.smartthings.com/
Thank you Hal. Still pretty lost. I’ll walk through what i see. This is where the IDE starts: A link to Get started integrating a hub-connected device.
Then, You don’t have any device handlers yet. Add one now.
Then this. Where do I go from here?
This does not lead me to three instructions in your message.
And if I click Switch, I get this, with no clue what do do with it.
Never Mind. I burrowed down into the Devices menu, found the unit, found how to change it. It works now.
Thanks very much.
Looks like the new edge drivers that Samsung put out don’t allow you to control both switches. Posted a message to the following thread to see if @philh30 would be willing to add support to his drivers: [ST Edge] Driver for GE/Jasco/Honeywell Z-Wave Switches, Dimmers, Fans, Outlets, and Plug-Ins
