Related/unrelated question: every time my hub gets an update or restarts, the time gets messed up.
My time based routines obviously don’t trigger at their correct times after this happens.
My hub came back on around 1:33 PM EDT.
Its now 3:49 PM and my 3:00 PM routines haven’t triggered yet.
Is there something i can do on my end to force the hub to resync it’s clock?
EDIT: This may not actually be a hub issue.
I just noticed that it only seems to be my Ikea Tradfri smart outlets that aren’t working properly following an update/restart.
The SONOFF Smart Outlets I have that have a 4:00 PM time based routine, and that worked as expected.
I took a closer look at the two different smart outlets I’m using and the one that is working as expected is using the Power On and separate Power Off routine options associated with the Zigbee Switch and Zigbee Switch Mc Edge drivers.
The ones that aren’t working as expected are using the combined “Power on and off” option for the routine.
That one is set up to be on from 8:00 AM to 11:00 AM and then again from 3:00 PM to 9:00 PM.
The “Power on and off” routines normally work fine, unless there has been a power outage or hub restart during the schedule period.
After some time has passed, they do go back to their normal execution.
I manually turned on the switches and will watch them later to see if they shut off at 9:00 PM as programmed, or if things remain out of sync until tomorrow’s routines run.
The two affected routines as called “Office Aquariums, Power on and off” and “Spec V, Power on and off”.
I’m experiencing the same thing with my On&Off routines. They just don’t get triggered, no outages to speak of. The app momentarily show a connected plug as “On”, but after syncing displays the Off
It’s very weird. For example, every other day or so it turns on at 10:00pm, even though, there are no routines present for that time. I vaguely remember creating one for it a few weeks back, but quickly deleting it. Yesterday, it dud come on at midnight, but never turned off.
