@andresg just wanted to let you know it happened again today after the zigbee firmware was updated on my hub.
Hub was rebooted while an affected routine was active.
The “Office Aquariums” routine was the only one affected by it.
Sorry for this inconvenient. This fix was rollbacked since we figure out it was causing some trouble on other features. The Automation team is working pretty hard to have this realeased again as soon as possible.
sorry, specifically I don’t know what feature you mean
Ah, my bad. I was talking about the issue a device changing driver made all automations using that driver stopped working.
Two of my simple routines that run in the hub (the non-hub routines are fine) are not firing. One of them is attached. I have done a hard and soft reboot of the hub but no luck - it was working till Tue this week. I tried pre-condition, non-pre condition but no luck so any thoughts?
If this is only supposed to run based on the time, change your switch off to a precondition.
As mentioned in my previous email, I tried putting the switch as a pre condition but still does not fire.
**Update - Figured out now, it’s the virtual switch that is stuck and not responding which explains why the automation did not fire.
