Ok, the most common reason for a routine set at a specified time not to run is that the hub was off-line sometime during that day. It doesn’t have to be exactly that time, sometimes if the hub was off-line earlier in the day it can cause later routines to be delayed or in a few cases missed all together.
Did you check to see if the hub itself had been off-line at any point during that day?
How about this one? All seems conditions are true. I can see the temperature sensor is reporting every minute as i configured, but for some reason the routine didnt’t trigger.
I was expecting it to trigger at 7:30 this morning.
I just tried turning off the switch manually from the physical button. The routine triggered immediately and turned back on. So i guess that part is expected.
At 7:30 the location mode was home. Nothing changed there since.
I can see why, but you’ll probably find the temperature condition only triggers the routine when it changes from false to true and it is already true at 7:30am.
You’ll need an extra routine to run at 7:30am to handle that border condition.
Not sure this is the correct thread to post, but here goes.
Running ST v3 with 46.8 as version.
I updated my Zooz switches to use the “new” Zooz edge drivers.
I created a routine to register when a door was open (samsung door sensor) and turn a light on in the room. I selected a custom time on the routine to turn the light off. I tried several custome times and none seem to turn off the light. I selected the predefined times of 1 and 10 minutes. Both of these turn the light off at the appropriate time.
Any one else experiencing this? Any ideas of what may be going on? Thanks!
