Aeotec Smart Home Hub/2018/2015 Model Hub Firmware Release Notes - 0.54.14
We will begin rolling out Samsung SmartThings Hub firmware version 0.54.14 starting on Monday November 4th. Once downloaded, your Hub will briefly go offline as it reboots and applies the update; most customers will experience less than one minute of downtime. We will update the status page when the release is complete.
Hub Target:
  • Samsung SmartThings Hub 2015 (Hub v2)
  • Samsung SmartThings Hub 2018 (Hub v3)
  • Aeotec Smart Home Hub
Release Date: 04 Nov 2024 - 11 Nov 2024
Note that this release will be spread out over multiple days, so you may not see your Hub update on the first day of the release period.
Release Notes
General
  • Fixed an issue preventing certain drivers with very large data stores from starting correctly
  • Fixed a rare issue affecting Matter and LAN device onboarding
Edge Drivers
  • Fix introduced that ensures that the init lifecycle event is handled before doConfigure
Anybody know what this is in reference to?
@orangebucket @Automated_House
Reminding you:
Two problems are missing:
  1. increase the transition of oflline time, so we won’t receive false offline states from zigbee devices that works on battery, that didn’t report status within 2 hours. I prefer 10 hours.
  2. Bring back HTML in custom capabilities edge driver to app as requested by @w35l3y here:[Feature Request] Allowing HTML in Custom Capabilities
App update (not hub). Please allow to choose language of the app. So, mobile phone can be 1st language and app will be other language.
This might explain why none of my matter devices are coming back online after some power outages. Cant for the life of me get them working. Also a load of Zigbee sockets keep dropping offline for no reason. Hopefully this sorts it
No, but a ‘rare issue’ being mentioned in brief release notes suggests it affected something pretty fundamental rather than something obscure. It could even be something as basic as encountering improbably long device names when onboarding.
I’m having the same issue and find turning of sharing for the matter device allows SmartThings to pick it up. I cancel the request but it comes back on line
Hopefully this will fix my problem with getting a 500 when installing some Edge drivers
There are several of us that started having this problem
Wish there was a way to force the update.
How long does it nomrally take for the update to get pushed to everyone?
I’m trying to sort how patient I need to be. My hub is currently almost as useful as a frisbee, but have been told that this .14 hotfix will fix my issues.
My concern is that my hub has a hard time responding to the internet. It always says it is “online”, but all other indications point to limitied or no connectivity (on and off). If it is in one of these “zombie” states when Samsung tries to push an update to it and it fails, how does one proceed to force an update?
nothing you can do
The announcement says it’s scheduled for November 4 through November 11. So more than a week.
It did NOT fix my problem… ugh
Aoetec Hub went offline and solid blue light around 11am today. Have tried several reboots since of both modem and hub. Still at solid blue light. I dont want to do factory reset as ill have to add all devices again.
you can try a soft reset:
soft factory reset by following these directions:
  • Disconnect the power cable from the Hub
  • if using Ethernet, leave it connected
  • Using a pin or a small tool, press into the reset slot on the back of the Hub
  • While continuing to press the pin in the slot, replace the power cable
  • When the LED on the front starts flashing yellow, release the pin from the reset slot
Tried that. It went back to solid blue.
next - you may want to try switching from Ethernet to Wifi or from Wifi to Ethernet - depends on which you are using
Thanks jkp. I tried the soft reset again and if went purple, flashing yellow, blue and finally green. So the hub is back online with the latest version of firmware installed. Most of my devices appead offline so ill likely have to readd them individually.
be patient on this… it may take a bit before they come back online
You have probably read this by now, posting for anyone else.
Fyi, Hotfix 54.14 did not fix the offline/online issue people started experiencing with 54.13.
I’m wondering if my hub will actually be able to recieve the update. My hub usually stays “online”, however, about an hour after I reboot the hub, it goes unresponsive. Unable to ping via ST/advanced or control any devices. If I reboot it works great for another hour or so.
This behavior makes me wonder if it will miss all the attempted firmware update pushes.
