A new error is reported for the SmartTings App
Hi, All:
A new error is reported as below:
It happened after I updated the SmartTings App on Android platform. I checked the hub status in SmartTings App:
Obviously, the hub connection is normal. And In my room, I also can watch some devices(added bofore the APP was updated) and the hub worked correctly.
Operation path: Add device ->By brand-> clicking any icon and any type product will find the error report.
The App version:1.7.67.29.
I can’t add devices to test my DTH. Who can solve this problem, please fix it as soon as possible, thank you!
Hi, @chenjun.
I was able to install a Z-Wave device correctly.
Please, try the following:
  • Clear the SmartThings app cache (from your mobile device’s configuration)
  • Instead of going to the brand, select scan nearby. When the device is identified (with the fingerprint), it will install the device using your custom DTH.
  • Make sure your device was previously deleted correctly (if Z-Wave, excluded from the network)
Thanks! I restarted my mobile phone and did as your said. Now I can add device normally.
