Hey everyone!
We’re excited to announce the start of a new SmartThings Hub Firmware Beta. Version 0.57.7 will begin rolling out in batches starting later today, May 12th, 2025. This will be a phased rollout so that we can keep a close eye on any issues that arise so your hub may not be updated immediately. The hub will be offline for about a minute during the update. See below for more specific details about the update.
Version
- 0.57.7
Hub Target
- Samsung SmartThings Hub 2015 (Hub v2)
- Samsung SmartThings Hub 2018 (Hub v3)
- Aeotec Smart Home Hub
Release Date
- Release Date: 12-May-2025
Help Us Help You
As part of our Beta program, it is important for our support team to investigate logs from Hubs running that are reporting errors. To provide our team access, please follow these instructions:
- Go to SmartThings Web (my.smartthings.com)
- Log in to your Samsung Account
- Select the Menu (⋮) and choose Settings
- Toggle on Account Data Access
- Select the time period and choose Confirm
Release Notes
- Add support for Matter Intermittently Connected Devices (ICD) utilizing the Long-Idle Time (LIT) feature
- Add Matter Time Synchronization support - the hub now serves as a trusted time source to provide connected devices that support time sync with accurate time.
- Updated mDNS library to improve discovery of Matter and LAN devices
- Fix issue preventing or delaying some Zigbee devices from receiving firmware updates in scenarios where more than 5 Zigbee devices are present
- Improve efficiency of managing stale Zigbee groups that are no longer used to control multiple devices at the same time
Edge Drivers
- Add the ability to register for some events (Switch, Switch Level, and some Zigbee sensors) to be processed and generated outside the edge driver to reduce latency.
- Bugfix to avoid loading subdriver code multiple times in certain cases
- Add support for receiving batches of commands instead of only single commands into edge drivers.
- Support using group commands when possible with Hue LAN edge driver.
NOTE
If you’d like to participate in the beta, please see these instructions for how to sign up or unenroll.
Anyone who participated in the previous beta is automatically signed up for this one, unless you have unenrolled.
