We’re excited to announce the start of a new SmartThings Hub Firmware Beta. Version 0.56.4 will begin rolling out in batches starting no sooner than Feb 11, 2025. This will be a phased rollout so that we can keep a close eye on any issues that arise so your hub may not be updated immediately. The hub will be offline for about a minute during the update. See below for more specific details about the update.
Version
0.56.4
Hub Target
Samsung SmartThings Hub 2015 (Hub v2)
Samsung SmartThings Hub 2018 (Hub v3)
Aeotec Smart Home Hub
*Release Dates
Release Date: 11-Feb-2025 Version 56.4
Release Date: 20-Feb-2025 Version 56.5
Release Date: 27-Feb-2025 Version 56.6
Release Date: 06-March-2025 Version 56.7
Release Date: 10-March-2025 Version 56.8
Release Date: 12-March-2025 Version 56.9
Release Date: 20-March-2025 Version 56.10
Release Date: 02-April-2025 Version 56.11
Help Us Help You
As part of our Beta program, it is important for our support team to investigate logs from Hubs running that are reporting errors. To provide our team access, please follow these instructions:
Reduce popcorning when controlling multiple Zigbee lights at once by using Zigbee groups
Popcorning refers when controlling a group of lights at once there is sometimes a visible delay before individual lights respond
This feature will be slowly rolled out after the release so you may not notice immediate changes
Used when controlling multiple Zigbee lights/switches/outlets from a rule that runs locally on the hub
Not currently used when controlling from a rule that runs in the cloud
Used when controlling a Lighting Device Group consisting of multiple Zigbee lights/switches/outlets from a rule, via voice, or from the device page in the app
Not currently used when controlling it from the device card in Favorites or Devices page in the app
Fix issue causing Schlage locks to frequently fall offline. Affected models include:
FE599
BE369
Upgrade to the Matter 1.4 SDK
Performance improvements with onboarding of Matter Bridges
Fix issue preventing some Sinope thermostats from joining
56.10 Released 20-March-2025
Fixed a bug related to offline diagnostics to help ensure diagnostics are available while hubs are offline.
Fixed a bug related to Multi-Hub which prevented a notification from being generated correctly
Edge Drivers
Cosock has been updated to return a handle when calling spawn that can be used to check if the coroutine is running or cancel a coroutine (note canceling a coroutine can only be made from a different coroutine)
Allow drivers to no longer sync full capability definitions to reduce memory usage.
Optimize handling of command batches from rules targeting multiple devices in a single driver.
Add support in default handlers for Zigbee power meter devices changing their ACPowerDivisor attribute
Fix edge case that could cause drivers to be unnecessarily restarted when the hub is under heavy load
Reduce duplicate messages from drivers to improve the responsiveness of important messages
Fix edge case causing occasional failures to configure Zigbee devices.
NOTE
Anyone who participated in the previous beta is automatically signed up for this one, unless you have unenrolled.
If you’d like to participate in the beta, but haven’t taken the survey yet: Sign Up Here
If you’d like to opt-out, update your preferences via the Account Settings menu item in Centercode or reach out to a SmartThings team member to assist.
When will the firmware release be? I’ve been waiting on this to be resolved since October. My account says I enrolled in beta 3 years ago however I have never seen any beta release’s on my device. I’m about ready to move all my locks over to the amazon ring hub because they constantly go offline all day long.
We’ll check with the team if you were enrolled correctly in the program.
For this, we need the email you use to login to Centercode, if it’s different than your SmartThings account, share that email as well.
Also, please open support access to your account so we can get some information of the Hub.
Confirm the email account registered in the forum is the same one you use for SmartThings. If not, please share it with me over DM
Select the time period and confirm - In this step, please select “Until turned off”, once the team finishes, we’ll let you know so you can disable it again.
