Hub V2 is not updating the firmware
Hello: how do I update my v2 hub.
It was offline for last 2 years, and shows Firmware version 000.028.00012 in App
I tried setting auto update to ON in iPhone App, and it always reverts back to manual update.
Also going to
My.smartthings.com to set update to public or beta throws the following error:
Error changing Zigbee OTA updates to “Allow except lightbulbs”. 504 504 Gateway Time-out
openresty
Even though my hub connects and is accessible via cellular connection.
Thank you
That setting is for device firmware updates and has no effect on hub firmware updates.
Tagging @nayelyz @Itati
Then how can I update my hub to the latest firmware?
Is there manual download option?
You’re probably going to need ST support to get involved. I tagged them for you but they may not respond until Monday since it Friday evening now and they may not be available on the forums. You can also try reaching out to support through the app by tapping on Menu and select contact us > error reports and tell them about the current firmware of your hub
Thank you, will do.
I appreciate your guidance.
Hi @Gurj_Singh
Just checking—are you still experiencing the same error?
After reconnecting a Hub that has been offline for a long time, it’s normal for the update process to take some time.
Please let us know if the issue persists
Hi Itati: yes, still experiencing the same issue.
Firmware version still showing up as 000.028.00012
Thank you,
Also, the hub has been reset and left ON for almost 2 weeks now, and the indicator still shows solid blue.
If that means the hub is trying to connect to the server?
Is it trying to reach an obsolete address?
I’d also enabled remote troubleshooting, and tried uploading the logs.
Thank you
I’m pretty sure that I’ve seen 28.12, which I think is several years old, being reported for reset hubs that turned out not to be properly connected to the ethernet and so had never completed their installation. Given that you are getting a solid blue light telling you that the hub is not connected to the backend servers I can’t see how the mobile app or web app can know what firmware your hub has unless it successfully connected some time previously and has now lost connection. What else is my.smartthings.com/advanced telling you? Does it show your hub having a valid IP address for example?
Hi Graham:
On
Samsung account page, I am not able to ping or reboot hub.
Trying to configure updates on advanced page throws this error:
openresty
However I am able to access the hub using Samsung App from remote location using Cellular data, and it shows as Connected.
Thank you
And, the IP address is’t listed on the advanced page.
Hi @Gurj_Singh
Can you enable support access to your account so I can check its details, please?
Hi Itati
Thank you for helping resolve the issue.
Hub did get the latest update, and working fine now.
Gurj
Hi, @Itati apparently I’m stuck in the same situation, my hub’s firmware is very old (000.025.00026) and the hub is failing to upgrade, I also enabled Account Data Access on my account and my smartthings email is the same as here. Will appreciate your help.
I reviewed your information and saw that it was added on 2025-06-27T11:21:26. It’s important to mention that after reconnecting a Hub that has been offline for a long time, it’s normal for the update process to take some time.
Thank you very much for a quick and informed response, I will wait for it to update. How long this can take? @Itati
Hi @Dmitry_Poznukhov
The update should have already been applied, but it hasn’t gone through yet. To help force the update, could you please assist by following these steps?
For these hubs, blocking NTP traffic during hub claim can allow the hub to connect to the hub firmware update server. This does require administrator access to your router and the ability to set Access Control Rules. The following steps outline how users with the necessary permissions and equipment access can proceed:
  1. Locate the steps provided by your home network router manufacturer to access the Router Settings / Admin Interface.
  2. In your Router settings, navigate to Access Control Rules and create a rule to disable UDP port 123 (NTP). (What is NTP Wiki). Please be sure to set only the source port as 123 and do not specify a destination port.
  3. Factory reset the SmartThings/Aeotec Hub.
  4. Go through the standard onboarding/hub claim process outlined in the hub documentation provided with the device.
    If you still have trouble claiming, please collect hub logs as outlined in the Troubleshooting section below before rebooting.
  5. Once the hub has successfully onboarded, remove the Access Control Rule created to block UDP Port 123. At this time, the hub should have updated its firmware to the latest supported version.
** If blocking the NTP port is not functional, another option some users have had success with, is blocking URLs for your specific region within the Access Control or Parental Controls. Here is a guide to find your NTP server for your specific region.
@Itati I am having this same issue except my ST v2 hub is not showing any firmware version in the ST Advanced Web app summary. I have already enabled Account Data Access and my email is the same as I use for Smartthings. Can you help push a FW update?
Hi @Terrell_Aubert
For these hubs, blocking NTP traffic can allow the hub to connect to the hub firmware update server. This does require administrator access to your router and the ability to set Access Control Rules. The following steps outline how users with the necessary permissions and equipment access can proceed:
I have a question, i have a V2 Hub that has never been used. i bought it new and kept as a spare incase my main one ever died. i tried to connect it the other day but it shows up as having no firmware and although it joins my location it cant do anything. is there any chance a V2 hub that has the original firmware from 2016 or so will be able to update itself and function or is it scrap now ?
