2 Locations in IDE/ Smarthings App
Hi
I am not able to delete a home location in the IDE - i have 2 somehow 1 had 1 device in which i have deleted and is not doing anything
when i click delete i ge this message
Oh No! Something Went Wrong!
Error
500: Internal Server Error
URI
/location/list
Reference Id
6d349f05-c3b2-4c40-be13-9f7c77801e80
Date
Fri Jan 18 09:22:44 UTC 2019
any ideas how to remove the location that i dont ned
rob
Did you create your original location with the old classic app and before the Samsung account migration?
If so then I had the same issue myself. The first time I used there new app it created an additional default location. I guess it just looks to see if a location has been created by the new app / Samsung account and does not see the original default location when it does this. Ideally you use the IDE to make this new location non-default, but I suspect like me you can’t do this and both show as default. In this case you need to raise a support case and ask them to remove it.
jkp - option 2 set option to false in incognito mode worked
thanks
