2 Default Locations
Hi
I seem to have a similar issue as previously described. I have been trying to get the new SmartThings iOS app to work. When I log in I have no devices. When I log into the ide I seem to have 2 locations, both of which have been set to default. Unfortunately the new smartthings app does not show my original location with all of the devices added.
I have contacted customer support and have been waiting 3 months for an update, when I chase it the response I get is that they are working on it and nothing more.
Has anyone else had this issue / any ideas on how to resolve it?
James
Do this help?
In order to delete a Home Location that has nothing in it:
  • Login to IDE at https://account.smartthings.com
  • Goto Locations
  • If you have multiple Locations, select the invalid one
  • Make sure there is no Hub associated to it
  • Scroll to the right and click Edit
  • If the Default Location shows ā€œtrueā€ (will be read only)
  • If it is ā€œtrueā€, go back to Locations and select your primary (Real) location and set the default location to ā€œtrueā€
  • Now you can edit/delete the additional Home location as it will automatically be set to ā€œfalseā€.
If that fails to resolve the issue, contact ST support and they can do it https://support.smartthings.com
Thanks for the responses
The issue I’m having is 2 fold.
1st the newer smart things app only shows a new location, which I assume was created during migration. This location has no hub assigned nor any devices.
2nd the IDE shows that both locations are default and therefore I cannot delete either.
Smart things support have not been helpful over the last 3 months of me questioning this!
I want to say choose the location with the hub and set it as the default and then delete the other location. But sounds like you have tried that. If support can not resolve, just rename the empty location, if you can, and forget about it. Not really what you want to hear.
I just had something very similar except the location I deleted did have all my devices. See if this might help:
