One device in particular seems to almost always be in error. Once in a blue moon, I will get no errors. Every time there are errors however, the 1 particular device is always in error while all the other devices in error are sporadic and different each time. Other times, it will be only the 1 device in error by itself if there are no other devices in error.
I have replaced this particular device numerous times with the same outcome. The only thing that “helped” was to install a repeater outlet about 4 feet away from the device that always is in error. This was the only way to get this device to actually work continually. If I hadn’t installed that repeater outlet, it would only allow me to add the device and then it would be totally unresponsive.
So any ideas on what I could do? Everything is working perfectly now, but this issue always pops up again where it will become un-responsive and always is in error regardless of whether it is responsive or not.
