Hi,
just got a Zooz Zen22 dimmer v2.0. Seems like a nice switch and works seamlessly with my Smartthings hub. I even already found the custom device handler and installed it.
The switch has a long default ramp-down time of 3 seconds, so when you press the switch it will take that long to dim down. My older Insteon devices had ways to configure this, even with button combinations on the switch itself. I have looked through the Zooz doc and the Smartthings UI, but haven’t found anything to that effect. Is there any way to configure this? If I need to mock around with the device handler groovy code, so be it.
Thanks,
Alex
