Zemismart Zigbee Switch Edge Drivers?
Hello guys! I’m a little desperate with the switch to smartthings edge because my whole house has zemismart switches. Can anyone help me by explaining how I will make them work on the new platform? Are there any drivers for them already?
Hi @Matheus_Trilico
Driver Zigbee Multi Switch Mc and zigbee Multi Switch Child Mc have the fingerprints.
    deviceLabel: 3A Smart 2 Switch
    manufacturer: 3A Smart Home DE
    model: LXN-2S27LX1.0
    deviceProfileName: two-switch
This is the my shared Channel link
Thanks a lot @Mariano_Colmenarejo!
Hello Mariano, how are you?? Im using your drivers for the past 2 weeks and Im experiecing a lot of malfuctions regarding automations, let me further explain.
I use some Zemi Smart switches as virtual paralels and others as scenes switches. When using as scene, sometimes they dont perform the scene at all. I deleted the scene then add it again, its works for some time and then it doesnt. Same thing with the paralels.
Im using the Touch version, Some of them are 3-Gang and Others 2 and 1. I have no problem with the 1-Gang Switches, but the 2 and 3-gang switches wont allow me to choose the state of the main light. I can choose to turn on or off the second or third touch button, but the main one only let me choose on/off. So when I programmed an automation to turn everything off i must use the all off function. I believe that could be the problem with the 3-gang switch. The 2-gang when im programming some virtual parallels, Im able to program the 2nd switch perfectly, but again the main one wont allow me to choose turn OFF as a State. Only ON/OFF.
Let me know if I was clear with my explanation and if you need further info.
Thank you for helping us, I really appreciate
This is a issue with IOs App
To not use virtual devices You can use new Zigbee Multi Switch and Child this allows you to create individual devices for the switch2, switch3 and all on-off . It works fine
Hi Mariano, Im alredy using this new driver. I guess I will have to wait until Smart thing Fix this bug for IOS.
Tks for your help.
Hello Again Mariano, attached you will find a picture of the problem Im facing. The 3-gang wont let me turn the main switch off during automations and scenes. When I select the all OFF Switch it activetes the Main switch ON, turn the 2nd and 3rd off then turn the main OFF again. Its Kind confusing. It will be much simpler if you could toggle/select the Main switch like the others During automations and scenes.
Please @Mariano_Colmenarejo can u add this (avatto 6 touch switch) to multi switch mc edge driver?
Thank you!
Hi @guipaviani
My driver only supports up to 5 components.
I would have to modify it.
When I can do it I’ll let you know
@Mariano_Colmenarejo i can disable one and use 5 only. :man_shrugging:t2: because i just have 4 lights in use.
If it is too complex for you to modify the edge driver, this will solve it for me for now.
What do u think ?
Added as 5 switches profile
When I can add new 6 profile then I will let you know
 Name         Zigbee Multi Switch and Child Mc
 Version      2022-10-19T12:27:04.348948652
  - id: "TS0006/_TZ3000_jyupj3fw"
    deviceLabel: TS0115 Switch
    manufacturer: _TZ3000_jyupj3fw
    model: TS0006
    deviceProfileName: five-switch  # need six-switch profile
Mariano how are you?? I believe something is not right with my drivers. Taking aside all the problems with automations, Alexa cant control the second and third switch unless I command the first one first. That make sense to you??
could you also take a look to the previous post I sent you, please.
Works fine Mariano! tks :+1::+1::+1::grinning:
Hi @guipaviani
Added profiles for 6 switches and 6 plugs in this version.
I don’t know if you will have to uninstall the device for the new profile to be applied correctly
 Version      2022-10-30T19:23:45.805719734
    model: TS0006
    deviceProfileName: six-switch
Congrats! Excellent work!
Tks Mariano.
Hi @Mariano_Colmenarejo, could you add this:
Hi @Dienzora
Added to this driver version
 Version      2022-11-03T15:57:41.846946542
  - id: "TS0003/_TZ3000_c0wbnbbf"
    deviceLabel: TS0003 Switch
    manufacturer: _TZ3000_c0wbnbbf
    model: TS0003
    deviceProfileName: three-switch
@Mariano_Colmenarejo thank you so much!
Hi Mariano_Colmenarejo,
Can you please add following fingerprint:
And also this:
Both ZigBee switches has worked flawless with old Zemismart Groovy DTH but I haven’t found any compatible Edge driver for each of swithes so far.
