Z-Wave Fan driver and ZOOZ Double Switch
I ran into 2 issues on a new deployment of SmartThings with Samsung GP-U9995JVLGSA 3rd gen hub.
  • Enlighten Fan controls reports as dimmer. It operates properly, both via the app an manually but shows dimmer slider (0-100%) instead of fan slider (off/low/medium/high). Compared to another implementation, I noticed that the hub is missing Z-Wave Fan driver but it should download automatically and I have no idea how to force it in.
  • ZOOZ Double Swith ZEN30 - added successfully, both dimmer and relay but although dimmer works just fine from the app and manually, the relay only works manually and shows its activity in history. When I try to control if from the app, it waits several seconds and displays “server or network error”. I tried Z-Wave Tools Network Repair but to now avail.
    Any suggestions would be greatly appreciated!
You need to install the proper drivers on your hub.
For Enbrighten
https://bestow-regional.api.smartthings.com/invite/JVMkKeg9VNMG
For Zooz
https://bestow-regional.api.smartthings.com/invite/adMKkbRABJM9
