Brocodd24
(Brocodd24)
February 6, 2024, 4:10pm
1
Is it possible to remove this Dimmer option? It’s not needed for setting my fan speed.
What is the manufacturer and model? What driver is the device currently using?
You can determine the details of the device at the advanced page for the web UI to your SmartThings account:
my.smartthings.com/advanced
Brocodd24
(Brocodd24)
February 6, 2024, 8:10pm
4
It’s a Enbrighten, Model 4944-3337. I believe my driver is from philh30 GE Z-Wave Switch/Dimmer/Fan/Outlet
Phil’s driver maps that device fingerprint to a device with a switch, dimmer level, a button, and fan speed. You might try switching to the stock zwave-fan driver which has the same fingerprint but maps it to a profile that is just a 3 speed fan with a switch. You can change the driver in the AWA mentioned in a previous post or via the mobile app.
derekwbeck
(Derek W Beck)
April 12, 2025, 9:44pm
7
How do I switch to the stock zwave driver? If the Advanced page, or the Android App, doesn’t let me select anything but Zwave Switch?
came here after posting my full problem on a new thread at
This is my 3rd zwave fan switch from the same brand, though probably older models. This one is:
Enbrighten Z-Wave Plus Fan Control, Works with Alexa, Google Assistant, 3-Way Compatible, ZWave Hub Required, Repeater/Range Extender, Smart Ceiling Fan Control, Smart Switch, White & Almond, 14314
There’s a new one, I know. But if you look carefully at the new ones, the white paddles now have a blue tint, and so I went with the old that matches the other Jasco dimmer beside, and the faceplate. This model has no QR code.
I haven’t added a fan “dimmer” in many many years, but I remember these were always troublesome. I’ve added it, excluded, added it again, but keep getting the same results: it comes up as a Z Wave Switch. If I go into select a different driver, it says No results found. My ot…
