A little advice please, I have 2 Xiaomi temp sensors which have continued to work perfectly for 2 years and still are even after migration, my issue is the device page, it shows every capability option ever made in a 5 or 6 page downward scroll
Temp and humidity are displayed on a single tile which is also wrong
I am using the Bspranger device type, is there a new device type for the Xiaomi temp sensors in the new app that displays only the devices capabilities ?
That is a bit weird. You can get problems like that if you try other DTHs with the device. I wince whenever I see it suggested. That sounds a bit drastic though.
Sadly that is outside our control. The plugin implements stuff that isn’t documented and indeed against explicitly created presentations.
I seed the attributes with unlikely values on install as the new app likes attributes to have valid values. I could test for existing values and use those but I like to make it obvious what has happened.
A combination of warm hands and a few huffs of moist air should bring some new readings if the sensor is accessible. Battery updates are every hour so one should come along in a while.
