Came across these in another thread (off-topic from the main thread), thought I’d post here as may be of interest and I’m selfishly interested if one of you guys wanted to have a look and feedback
Xiaomi appear to have added some Zigbee switches to their product line recently. The community have had some good success getting Xiaomi:
temp/humditysensor
contact sensor
cube (7 button remote)
motion sensor
appliance plugs
working, often by trial and error. The kit is well made, cheap and it generally looks very good (the motion sensor is tiny). If you’re interested in that have a look here:
There’s a battery powered and a mains powered option. The reason for posting here is because I believe the wired version might be of interest to us here in the UK. It looks like it requires no neutral.
So if anyone has looked at these, intends to, or has any comments let us know!
Yes. You are right, it doesn’t require neutral and is stateful. This is a push button switch and would be awesome if it has a on/off light indicator on the physical switch.
I have it integrated with ST via home-assistant.io (MQTT) / Xiaomi Gateway.
@PailOckenden there seems to be two types of backs to these. One claims to be a european back but round, which may suit all countries outside the british isles.
@PBrain, no one has mentioned that they have tried them in ST and AFAIK there is no public available DH. They have been used with Home Assistant and the User was happy with these switches.
Yep this was what I had assumed. However, given that various invididuals have been furiously working on DHs for all the other Xiaomi devices…I Just wondered if we were any further forward with the wall switches…
I got mine yesterday. But the problem is I have a round hole and the Aqara is square. I hoped that it would fit either way but it did’nt, Kept it hanging out and plugged it in, ST dont recognize it as a thing. Did’nt waste to much time on it, so dont know if it works with a device handler or not.
I received one QBKG04LM switch from AliExpress, it will not pair with the hub and does not show up as a thing. However the hub is seeing the switch and capturing on/off events in the IDE live log when the switch is pressed. For some reason the Hub IDE log reports the events back against “Smart Connect TV”.
I have tried several device handlers with no success, heres what the log is seeing.
