Wrong hub put into pairing mode using latest Android app?
Using the latest Android app with two hubs on the same location and pairing a hub connected device.
If I use ‘Scan Nearby’ I am offered a choice of hub and the correct one is put into pairing mode.
If I go in via a ‘Brand’ I am offered a choice of hub but the same one (the first of the two in my list for me) is put into pairing mode regardless of the choice I make.
Anyone else seeing that? This is new behaviour to me.
Since the last update the onboard process seems prettier but quirkier. As ever, when you onboard by ‘Brand’ any other devices you have paired using ‘Scan Nearby’ lately are ‘found’ again and moved into whatever room you chose for the device you are trying to pair. That has happened forever. Now I also find that when I am re-pairing an existing device, I will often get a new one instead.
I have the exact same problem. Only way I can add devices is to scan nearby. Exclusion mode works fine, but adding a device by name or QR code my hub never goes into paring mode.
I put a third hub on a different location just to play with and that became the one that was always selected. I find it strange enough to be offered a hub in a different Location to start with.
I did report this back in July and, after submitting a video, it was acknowledged as a bug. I am somewhat surprised there hasn’t been a fix yet as not being able to add devices via the intended method seems like a pretty major problem.
