Welcome code for Smarthings hub v2
Hello, I purchased a 2nd hand v2 hub and I didn’t get the welcome code with it. Can someone help me with getting the code? My SN#3000262594 Thanks in advance @nayelyz @Itati
Hi, @EpicRain,
Welcome to SmartThings. The V2 hub is still a solid choice (I still use mine).
For a welcome code, you need to either contact the SmartThings help desk or tag one of the very helpful SmartThings staff on this forum.
Tagging @Itati @nayelyz
Hi @EpicRain
I sent you the welcome code through a DM
@Itati. Sorry to jump on this thread, but I have a similar problem. Got a new phone and trying to connect my V2 hub, but can’t find the code card. Could you help me, please. Serial number is: 4000145599 Thanks Anke
Hi @Anke_Otto
I reviewed your Hub, and it appears as ‘CLAIMED.’ This means it is already installed on the SmartThings platform, and you won’t be able to claim it with another account. Here are some instructions to reset the Hub:
  1. Connect the Hub via ethernet
  2. Then, follow the steps to factory reset it. Here’s a link that has the instructions for different models:
    Factory reset or reboot your SmartThings Hub
Please let me know once the reset is complete, and I’ll be happy to assist further.
Sorry, not trying to reclaim it. Just trying to get the app to show the local devices on my new samsung phone. Worked with other phones in the past. Maybe I am using the wrong email to connect… I’m worried that if I reset it I will lose all the local routines.
No worries at all, thanks for clarifying.
I’d recommend double-checking which email you used on your previous phone and making sure you log in with that same one on your new Samsung device. When switching to a new phone, it’s only necessary to log in with the correct email address, since all your data — including local devices and routines — is linked to that account.
And you’re right, doing a full reset could delete your local routines, so it’s best to try account verification steps first.
Thanks for the help. Was using the wrong email account - DOH! All devices listed now!
I too have a v2 hub that I previously used at my old home. I deleted everything in lieu of my smart tv acting as the main hub but want to set up my old v2 for ZWave devices. Can someone help with a welcome code?
Also, thinking of purchasing a new aeotec hub to expand my matter network, is anyone running 3 hubs successfully in one home?
Could you please share the serial number?
Hi @Itati I need to factory reset my Smartthings hub V2 as i need to change my account county code. I don’t have the welcome code. Do I need to first reset the hub? (SN# 3000341546). Really appreciate if you could send me the welcome code. Thanks
Hi, yes, you’ll need to factory reset the hub first. Once the reset is completed, please let me know and I’ll be able to provide you with the welcome code so you can set it up again.
Thanks for the prompt reply. I’ve factory reset the hub. Appreciate it if you could send me the welcome code. Many thanks
Hi @asantha
Thank you for your support. Everything is working perfectly!
Hello, can I get a welcome code. SN # 3000219989
Hi @Adam_Jones
Hello, I too need the welcome code for the v2 hub. Serial number is 3000219057
@Rick_M1
