Hi, I’m trying to set up an old SmartThings v2 hub I found. I was on the original v1 kickstarter, got the v2 at some point, and I’m not sure I ever set it up. Now I need zwave support again, and remembered I had it. I believe I need a welcome code but I don’t have one.
@Itati@nayelyz could you help me get a welcome code (I saw you tagged on a similar post)? My serial number is 3000112844. Thanks!
I reviewed your Hub, and it appears as ‘CLAIMED.’ This means it is already installed on the SmartThings platform, and you won’t be able to claim it with another account. Here are some instructions to reset the Hub:
By the way, I accidentally connected the power adapter while the batteries were still inside, which caused the adapter to stop working and completely drained the batteries within a day. I then attempted a factory reset, thinking I could easily repair the device. As part of that process, I removed it from the SmartThings app. Now, it’s asking for the welcome code, which I no longer have and don’t remember saving anywhere.
I hope I’m going about this right. Anyways, I purchased a used Smart things hub at a reseller recently, and came across these posts. Although I have the original box, there’s no documentation or manuals included. Could you please help me get a welcome code for model STH-ETH-200, serial # 3000389757? Your help would be certainly appreciated, thank you!
Hi there. Just got a used STH-ETH-200 off eBay. I want to extend my existing network. I can’t add it because there is no welcome code printed inside. Can you help please?
