Visonic MCT-340 E as Garage open/close sensor
Does anyone use following sensor for Garage door open/close? If yes then are you using a modified DTH?
Visonic MCT-340 E Wireless Door Window and Temperature Sensor 2.4ghz ZigBee
I had a ST Multi sensor which recently died so trying to find a replacement which can notify me when garage is opened/closed.
I did for a while but just swapped to using a Monoprice garage sensor. When I was using the Visonic I used the standard DTH. I did have to use the Visonic to get it to connect but then swapped it . The reason I switched devices was that I couldn’t get the contact sensor to always set to closed when the door closed. This was mostly due to having too much of a gap between the sensor and magnet based on how my garage door is set up. I use the sensors on normal house doors and they work great.
