How in the hell are you all getting this device to work?!?! I’ve followed the instructions to the letter and still nothing. So my next attempt was to reset the device, delete the device handler and just start over. There is nothing showing up under Device Handlers. Now when I create a device handler from code, paste the code, and select Publish, it displays this error:
a different object with the same identifier value was already associated with the session:
[physicalgraph.device.CapabilityDeviceType#physicalgraph.device.CapabilityDeviceType : (unsaved)];
nested exception is org.hibernate.NonUniqueObjectException:
I’ve tried deleting everything and manually adding them as a SmartSense device, but still nothing. I have confirmed that I have a v2 hub. I’m ready to throw these damn things out the window…EXCEPT I don’t know if the window is opened or closed because I can’t get the f$%&!ng things to work!!!
What gives?!?! Any suggestions?
