gingertips
(Richard Smart)
October 5, 2024, 9:37pm
1
Hi all. My v2 hub has died. Tried to use batteries and that doesn’t work either. Ive got a few devices setup so be good if i can replace on my account this new hub without having to factory reset so many devices.
What are my options? Thanks
Get an Aeotec SmartThings Hub and use the
As our Hub Everywhere strategy continues to grow and make SmartThings hub technology more available than ever before, the need for customers to use the hub of their choosing is more important than ever. To help with this, we are excited to announce the release of our new Hub Replace feature. Hub Replace enables users to transfer everything from their current hub to a new one without having to manually reconnect each device or recreate Routines.
While we are excited about the increased flexibility this gives users in their hub choice, we are equally excited about the increase in reliability and peace of mind it brings to users’ smart homes. This is because the Hub Replace feature is also available to transfer device and Routine setups from a currently offline hub to a new hub in a worst ca…
And it works! Make sure to read how:
Earlier this week my V3 Samsung branded hub failed. The power supply was putting out 0 volts so I got a replacement, but the hub was DEAD.
So I ordered the same hub as a replacement, added it to my home, and DID NOT MAKE A HUB PAIR even though setup hit me with a huge prompt to do so.
Once the new hub was added I went to the settings of the failed hub and saw the Replace Hub option had appeared. My understanding is the prompt only appears when you add a new hub that is available as a replacement.
I selected the Replace Hub, clicked through the screens, and after 3-5 minutes everything was active on the new hub.
It took another 5-10 minutes for all the devices to become live on the new hub.
After that everything just…worked. Like, perfectly. I didn’t have to do anything, troubleshoot a…
jkp
October 5, 2024, 10:36pm
3
is the led light off or does it show any color?
jkp
October 10, 2024, 2:53pm
5
once you purchase a new hub and connect it… you can use Hub replace as noted in the first response. It would use the last backup of your old hub. Please do not attempt to remove the old hub from the app until you add the new hub and use Hub replace.
gingertips
(Richard Smart)
October 10, 2024, 3:30pm
6
thank you guys. following from advice, I got hold of a V3 device. Did the following:
switched on new device
opened the android app on phone. added new hub. It setup in a couple of minutes after an update
went to old device in the app, then the 3 buttons & chose replace hub
replacement took seconds
within about a minute all my existing devices were working once more!
Am over the moon - I think this is the first time that anything Smartthings has actually worked without a lot of effort!!!
Sorry to jump in. For future reference, would hub replace work for v2 to v2 hub please? (I have a spare v2). TIA
jkp
October 10, 2024, 10:38pm
8
Yea, you should be able to use hub replace between two v2 hubs
