I know this question has been beaten to death a bit, but I haven’t found a reliable solution anywhere, so I’m posting anew.
I recently purchased two of the ZWave Plus motion sensors from Monoprice.
Out of the box I had trouble pairing both of them, but eventually one got paired.
The other still will not pair.
I’ve removed the cover, set ST Pairing mode, inserted the battery, and held the sensor very close to the hub. I’ve also inserted a pin to push the program button in the back. The LED flashes on/off repeatedly, but the sensor is not detected by my hub. I’ve tried hitting the program button once, hitting it repeatedly, holding it, holding then tapping, etc… The LED flashes, but ST doesn’t pick it up.
I’ve also tried the same procedures with my SmartThings system in Exclusion mode, but it doesn’t detect the sensor in Exclusion mode, either.
And I’ve installed RBoy’s device handler, which is working well for the other sensor.
Any advice? Ideas?
