Which error, can you share a screenshot about it?
I tried the link you shared and it wasn’t working for me either because I didn’t accept the invitation, I was able to enter once I used this one: https://bestow-regional.api.smartthings.com/invite/1PlYENKbdNle, and, clicked on “Accept”.
@nayelyz I realize this is low priority, but this issue should be ticketed to fix the process when someone clicks on a driver link without first joining the channel. I’m sure your engineers can find a more graceful solution than a spinning wheel. It will reduce frustration and support calls.
Thank you all that helped with this. I now can enroll with no problem. Thank you all.
Same here. Able to join channels now
Good to go now! Thanks everyone
Have you installed this Edge driver and, if so, can you tell me what features it allows? I have a rBoy DTH installed which allows management of multiple lock codes and some other things. It’s still working and I don’t want to delete it if the new one doesn’t at least let me manage multiple codes. Also, I have an original Connect Home hub.
You need to ask @leeduhl , I just quoted their post.
Also. Multiple people have reported issues with the Wi-Fi, mesh hub models, including the connect home, and edge drivers. You might want to check out those forum topics before making any irrevocable changes.
Thanks. I’ve only had one Edge driver problem that required that I use an older version of the driver. Others seem to work ok. However, I am going to upgrade my hub soon, but need to get a router 1st. The Connect Home has a built in wifi router, but the new ones don’t.
(post deleted by author)
