I followed the instruction for the Hello World edge driver sample. Everything went smoothly except attaching to the hub to see logs.
PS C:\sample\HelloWorld> smartthings.exe edge:drivers:logcat --hub-address=192.168.1.12
Error: Request failed with status code 403
Apparently I need to tell the hub to allow log listening. How do I do that?
nayelyz
(SmartThings Developer Support)
September 17, 2021, 6:48pm
2
This issue could be related to the generated Access Token. If you run the command smartthings edge:drivers, do you get a result or the same error?
I get a result. As I mentioned all steps went smoothly. I installed the driver to the hub, I just cannot attach the log listener.
PS \DayPartDriver> smartthings.exe edge:drivers
βββββ¬βββββββββββββββββββββββββββββββββββββββ¬ββββββββββββββ¬βββββββββββββββββββββββββββββ¬βββββββββββββββββββββββββββββ
β # β Driver Id β Name β Version β Package Key β
βββββΌβββββββββββββββββββββββββββββββββββββββΌββββββββββββββΌβββββββββββββββββββββββββββββΌβββββββββββββββββββββββββββββ€
β 1 β 47fb3018-ff74-3099-ab3f-8830be5fa830 β Hello World β 2021-09-17T15:02:25.696774 β com.smartthings.helloworld β
βββββ΄βββββββββββββββββββββββββββββββββββββββ΄ββββββββββββββ΄βββββββββββββββββββββββββββββ΄βββββββββββββββββββββββββββββ
iquix
(Jaewon Park)
July 15, 2022, 4:09am
4
I also have exactly same problem here.
I have two ST hub. One works fine, but only the newly installed hub has this problem.
I can install the driver, and get the list of the installed driver, but only logcat fails.
(which means, thereβs no problem with the token)
This is a V2 hub and the hub firmware version is 43.4.
think@utility:~$ smartthings edge:drivers:installed
βββββ¬βββββββββββββββββββββ¬βββββββββββββββββββββ¬βββββββββββββββββββββββββββββββββββββββ
β # β Label β Name β Device Id β
βββββΌβββββββββββββββββββββΌβββββββββββββββββββββΌβββββββββββββββββββββββββββββββββββββββ€
β 1 β Smartthings Hub V2 β SmartThings v2 Hub β c1cba303-52ef-4344-b9d0-027a7d831f04 β
β 2 β Sub Hub β SmartThings v2 Hub β e09cd8a8-4a97-4bd8-870c-40e7968aef52 β
βββββ΄βββββββββββββββββββββ΄βββββββββββββββββββββ΄βββββββββββββββββββββββββββββββββββββββ
? Select a hub. 2
βββββ¬βββββββββββββββββββββββββββββββββββββββ¬βββββββββββββββββββββββββ¬ββββββββββββββ¬ββββββββββββββββββββββββββββββββ¬βββββββββββββββββββββββββββββββββββββββ¬βββββββββββββββββββββββββββββββββββββββ¬βββββββββββββββββββββββββββββ
β # β Driver Id β Name β Description β Version β Channel Id β Developer β Vendor Summary Information β
βββββΌβββββββββββββββββββββββββββββββββββββββΌβββββββββββββββββββββββββΌββββββββββββββΌββββββββββββββββββββββββββββββββΌβββββββββββββββββββββββββββββββββββββββΌβββββββββββββββββββββββββββββββββββββββΌβββββββββββββββββββββββββββββ€
β 1 β ba6d83e8-6d7a-4559-b5ea-c08d8c6d8ba9 β Zigbee Switch by iquix β β 2022-06-24T12:42:09.448573395 β 4c1b2a74-f52f-4f5e-bf7b-462d0cdf63e3 β 53b520de-9819-8e38-dce1-811c5b1ecbf8 β β
βββββ΄βββββββββββββββββββββββββββββββββββββββ΄βββββββββββββββββββββββββ΄ββββββββββββββ΄ββββββββββββββββββββββββββββββββ΄βββββββββββββββββββββββββββββββββββββββ΄βββββββββββββββββββββββββββββββββββββββ΄βββββββββββββββββββββββββββββ
think@utility:~$
think@utility:~$ smartthings edge:drivers:logcat --hub-address=192.168.254.65
ββββββΌβββββββββββββββββββββββββββββββββββββββΌβββββββββββββββββββββββββββββββββββ€
β 1 β 49a06f66-77a5-4cad-b71b-b7a65fa221a7 β HA.Motion β
β 2 β 97cd8778-c0f3-4e15-a350-4607e7102e02 β HA.Switch β
β 3 β 5964d4b5-2741-40da-8e21-42e1ae6f53a2 β Hue Dimmer Switch β
β 4 β 9d00eaef-fd7f-4719-9af3-1392a23a0592 β Hue Motion Sensor β
β 5 β 5e8e298f-706e-4c71-8f0f-888a4111972b β LUMI Illuminance Sensor β
β 6 β b713725a-a2ed-448e-b274-e6a23894a1e5 β Power Trigger Switch β
β 7 β e977cb81-1021-41a6-a9e6-6a641989fd12 β Temperature Humidity TVOC Sensor β
β 8 β 2ccd5a45-9748-457e-8833-9bfd076e2a69 β Tuya Window Shade β
β 9 β 3fb97b6c-f481-441b-a14e-f270d738764e β Zigbee Button β
β 10 β aa79374d-a9a1-44e2-856c-d914f40d0bfb β Zigbee Button β
β 11 β ae11bc43-2992-4d21-aaac-1d5d32a4ae6a β Zigbee Button β
β 12 β 408981c2-91d4-4dfc-bbfb-84ca0205d993 β Zigbee Contact β
β 13 β 002b960f-0ea4-4776-b517-c9a6a582b193 β Zigbee Counter Sensor V3 β
β 14 β 89fc289e-607a-49ba-95c5-a7beccbc9516 β Zigbee Motion Sensor β
β 15 β f2e891c6-00cc-446c-9192-8ebda63d9898 β Zigbee Switch β
β 16 β ba6d83e8-6d7a-4559-b5ea-c08d8c6d8ba9 β Zigbee Switch by iquix β
? Select a driver. (all)
connecting... done
think@utility:~$ smartthings edge:drivers:logcat --hub-address=192.168.254.104
connecting... failed
think@utility:~$
You can see that the ip address of the hub given to the CLI is correct
iquix
(Jaewon Park)
July 15, 2022, 1:04pm
5
Update:
After I create a new location, and then add the hub to that new location, then logcat works.
It seems that if there are multiple hubs in a location, then logcat raises error with the second hub.
I think it does not allow multiple certificate fingerprints of multiple hubs in one location.
It seems that thereβs a bug in CLI dealing with it.
nayelyz
July 15, 2022, 3:30pm
6
Thank you for bringing this to our attention. Iβll create a report for further investigation. Once I get more info, Iβll let you know.
nayelyz
July 15, 2022, 8:58pm
7
Following up, @iquix . Can you provide the following info, please?
Does the original location belong to you or youβre only a member?
Which version of the CLI are you using?
Weβve seen there are differences in the CLI between location owners and membersβ¦
iquix
(Jaewon Park)
July 16, 2022, 1:23am
8
The location belongs to me
I was using 1.0.0-beta4, linux version.
After creating a new location and adding the hub to that new location, I got following message about certificate fingerprint (instead of the 403 error as I mentioned above)
and then it works fine, even if I re-added the hub to my original location. (updated info)
I canβt regenerate the error now, since certificate fingerprint of the new hub is correctly added to the CLI thereafter.
(I have no idea where that certificate fingerprint and list of know hub is stored though)
It seems that there might be some bug handling certificate fingerprints when new hub is added.
nayelyz
July 18, 2022, 3:02pm
9
These are the folders where the files generated by the CLI are saved:
$HOME/.config/@smartthings/cli on MacOS or Linux
%LOCALAPPDATA%\@smartthings\cli on Windows
Thereβs a file called βknown_hubsβ but if itβs working now, I suggest you donβt modify those files as I donβt know how it could affect the CLI.
Iβll create the ticket mentioning your observations to try to replicate it on our side, if we need your help, Iβll let you know,
