DTH or Edge driver for Aubess Tuya Zigbee Leak / contact
Has anyone managed to get a driver for the Aubess Tuya Zigbee - Leak sensor
Aubess Tuya Zigbee Home Alarm Water Leakage Alarm Water Leak Sensor Detector Flood Alert Overflow Smart Life Smart Home|Home Automation Modules| - AliExpress
tagging @Mariano_Colmenarejo
It would be necessary the model, manufacturer and the clusters that are shown in the IDE to know if it can be added to any existing driver.
		DEVICE
	</td>
	<td class="uuid"></td>
	<td>
		<a data-toggle="tooltip" title="clustersInfo" class="tooltip-init" >clustersInfo</a>
	</td>
	<td>
		<a class="tooltip-init" title="&lt;table style=&#39;font-size:60%&#39;&gt; &lt;tbody&gt;&lt;tr&gt; &lt;th align=left&gt;&lt;/th&gt; &lt;td&gt;&lt;em style=&#39;color:Green;font-weight: bold;&#39;&gt; Server Clusters:&lt;/em&gt;&lt;/td&gt;&lt;/tr&gt;&lt;tr&gt; &lt;th align=left&gt;&lt;/th&gt; &lt;td&gt;&lt;b&gt;Ep: &lt;/b&gt;01={ 0001,0003,0500,0000 }&lt;BR&gt;&lt;/td&gt;&lt;/tr&gt;&lt;tr&gt; &lt;th align=left&gt;&lt;/th&gt; &lt;td&gt;&lt;em style=&#39;color:Blue;font-weight: bold;&#39;&gt; Client Clusters:&lt;/em&gt;&lt;/td&gt;&lt;/tr&gt;&lt;tr&gt; &lt;th align=left&gt;&lt;/th&gt; &lt;td&gt;&lt;b&gt;Ep: &lt;/b&gt;01={ 0019,000A }&lt;BR&gt;&lt;/td&gt;&lt;/tr&gt;&lt;/tbody&gt;&lt;/table&gt;" data-toggle="tooltip">
			&lt;table style=&#39;font-size:60%&#39;&gt;...
		</a>
	</td>
	<td>
	</td>
	<td >
		<a class="tooltip-init" title="" data-toggle="tooltip">
	</a>
	</td>
		<td>true</td>
</tr>
<tr class="">
	<td>
		<a href="/device/6c1eba93-c5af-4ab3-a307-6c52b6fcdedf/event/405efa9a-0c40-11ed-8b37-d191da018592?all=true&amp;source=&amp;max=25">
			<span class="eventDate">
				2022-07-25 7:36:01.000 PM CEST<br />
				<em>8 minutes ago</em>
			</span>
		</a>
	</td>
	<td>
		DEVICE
	</td>
	<td>
		<a data-toggle="tooltip" title="manufacturer" class="tooltip-init" >manufacturer</a>
	</td>
	<td>
		<a class="tooltip-init" title="_TZ3000_upgcbody" data-toggle="tooltip">
			_TZ3000_upgcbody
		</a>
	</td>
	<td>
	</td>
	<td >
	</a>
	</td>
		<td>true</td>
</tr>
@mickfff
I note to add it to the st zigbee moisture sensor Mc driver.
It will be in August, when I have access to the cli
Hi @mickfff
I can see de manufacturer: _TZ3000_upgcbody, but I can’t see the model
I get TS0207 but I believe that is the edge driver for a different model.
Can I get any other data from the IDE for example?
Yes, in IDE you can see the model
I’m not seeing anything from this in live logging. It pairs as a Zigbee thing but the device page has no indications / states. Just Status: Connected!
Install zigbee thing Mc from my channel and do a driver change from zigbee thing.
This is how the manufacturer and model will look
@mickfff ,
If device was paired with a DTH then In IDE you can see this info cliking in device
With your edge driver I only get:
Hi @mickfff
With zigbee Thing Mc you must see some as this in the app device.
After driver change, close app, clear app cache if you use android and reopen app
@mickfff
Added to this driver version
β”Œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”
β”‚ Name        β”‚ ST-Zigbee Moisture Sensor Mc         β”‚
β”‚ Version     β”‚ 2022-08-10T11:49:41.119841538        β”‚
β””β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”˜
  - id: "_TZ3000_upgcbody-Sensor"
    deviceLabel: TS0207 Water Sensor
    model: TS0207
    deviceProfileName: moisture-battery
WOW !
Working now battery & water detection!
Thank you!
@Mariano_Colmenarejo Hi, can you please include this water sensor device in the Moisture Sensor Mc driver?
Hi @reinaldots
β”‚ Name        β”‚ Zigbee Moisture Sensor Mc            β”‚
β”‚ Version     β”‚ 2022-09-06T18:10:57.648979374        β”‚
  - id: "_TYZB01_sqmd19i1-Sensor"
    manufacturer: _TYZB01_sqmd19i1
    model: TS0207
It worked just fine! Thanks @Mariano_Colmenarejo
