I have a GE Light switch which I can set a routine to turn on when motion is detected. I do not want to set the DIM value as I prefer to set it manually at the switch. However routine always set to high brightness when I ask it to turn on using a routine. Anyone know how to achive this?
Motion detected → then → Turn on GE switch (but don’t set the dim %)
How to do this?
GE switch is a z-wave device, and seems to run with a local driver now. (I am not familiar with the new drivers.)
Logs suggest, Routine set the switch to on and set the level to 100. I don’t think this is acceptable. I also tried the smart lighting it does the same.
This used to work fine with web-core, now what will be my alternative?
