For what its worth, I sill haven’t resolved the issue with this device handler and STsupport is yet to be helpful with the error. I did contact Aeon support and they recommended the attached device handler with I believe was also written by @johnconstantelo. It works so I’m not sure if its helpful for comparison sake?
Aeon HEM12
Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
in compliance with the License. You may obtain a copy of the License at:
http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
for the specific language governing permissions and limitations under the License.
Aeon Home Energy Meter v1 (US)
DrShaw Modifications: Updated configuration settings and tiles
metadata {
definition (name: “My Aeon Home Energy Monitor v2”, namespace: “jscgs350”, author: “SmartThings”)
capability "Energy Meter"
capability "Power Meter"
capability "Configuration"
capability "Sensor"
capability "Refresh"
capability "Polling"
capability “Battery”
attribute “energy”, "string"
attribute “energyDisp”, "string"
attribute “energyOne”, "string"
attribute “energyTwo”, “string”
attribute “power”, "string"
attribute “powerDisp”, "string"
attribute “powerOne”, "string"
attribute “powerTwo”, “string”
command "reset"
command "configure"
command “resetmaxmin”
fingerprint deviceId: “0x2101”, inClusters: " 0x70,0x31,0x72,0x86,0x32,0x80,0x85,0x60"
// tile definitions
tiles(scale: 2) {
multiAttributeTile(name:“powerDisp”, type: “lighting”, width: 6, height: 4, decoration: “flat”, canChangeIcon: true){
tileAttribute (“device.powerDisp”, key: “PRIMARY_CONTROL”) {
attributeState “default”, action: “refresh”, label: ‘${currentValue}’, icon: “st.switches.light.on”, backgroundColor: “#79b821”
tileAttribute (“statusText”, key: “SECONDARY_CONTROL”) {
attributeState “statusText”, label:’${currentValue}’
// Power row
valueTile(“energyDisp”, “device.energyDisp”, width: 2, height: 2, inactiveLabel: false, decoration: “flat”) {
state(“default”, label: ‘${currentValue}’, backgroundColor:"#ffffff")
valueTile(“energyOne”, “device.energyOne”, width: 2, height: 2, inactiveLabel: false, decoration: “flat”) {
valueTile(“energyTwo”, “device.energyTwo”, width: 2, height: 2, inactiveLabel: false, decoration: “flat”) {
// Controls row
standardTile(“reset”, “device.energy”, width: 2, height: 2, inactiveLabel: false, decoration: “flat”) {
state “default”, label:‘Reset All’, action:“reset”, icon:“st.secondary.refresh-icon”
standardTile(“refresh”, “device.power”, width: 2, height: 2, inactiveLabel: false, decoration: “flat”) {
state “default”, label:’’, action:“refresh.refresh”, icon:“st.secondary.refresh”
standardTile(“configure”, “device.power”, width: 2, height: 2, inactiveLabel: false, decoration: “flat”) {
state “configure”, label:’’, action:“configure”, icon:“st.secondary.configure”
valueTile("battery", "device.battery", inactiveLabel: false, decoration: "flat") {
state "battery", label:'${currentValue}% battery', unit:""
valueTile("statusText", "statusText", width: 3, height: 2, inactiveLabel: false) {
state "statusText", label:'${currentValue}', backgroundColor:"#ffffff"
valueTile("min", "powerOne", width: 2, height: 2, inactiveLabel: false, decoration: "flat") {
state "default", label:'Min:\n${currentValue}', backgroundColor:"#ffffff"
valueTile("max", "powerTwo", width: 2, height: 2, inactiveLabel: false, decoration: "flat") {
state "default", label:'Max:\n${currentValue}', backgroundColor:"#ffffff"
standardTile("resetmaxmin", "device.energy", width: 2, height: 2, inactiveLabel: false, decoration: "flat") {
state "default", label:'Reset Max/Min', action:"resetmaxmin", icon:"st.secondary.refresh-icon"
main (["powerDisp"])
details(["powerDisp", "energyDisp", "energyOne", "energyTwo", "min", "max", "refresh", "resetmaxmin", "reset", "configure"])
preferences {
input "kWhCost", "string", title: "\$/kWh (0.16)", defaultValue: "0.16" as String
// log.debug "Parse received ${description}"
def result = null
def cmd = zwave.parse(description, [0x31: 1, 0x32: 1, 0x60: 3])
if (cmd) {
result = createEvent(zwaveEvent(cmd))
// if (result) log.debug “Parse returned ${result}“
def statusTextmsg = ““
statusTextmsg = “Home is currently using ${device.currentState(‘powerDisp’).value}.\nMin was ${device.currentState(‘powerOne’).value}.\nMax was ${device.currentState(‘powerTwo’).value}.“
sendEvent(“name”:“statusText”, “value”:statusTextmsg)
// log.debug statusTextmsg
return result
def zwaveEvent(physicalgraph.zwave.commands.meterv1.MeterReport cmd) {
//log.debug “zwaveEvent received ${cmd}“
def dispValue
def newValue
def timeString = new Date().format(“yyyy-MM-dd h:mm a”, location.timeZone)
if (cmd.meterType == 33) {
if (cmd.scale == 0) {
newValue = cmd.scaledMeterValue
if (newValue != state.energyValue) {
dispValue = String.format(”%5.2f”,newValue)+”\nkWh"
sendEvent(name: “energyDisp”, value: dispValue as String, unit: “”)
state.energyValue = newValue
BigDecimal costDecimal = newValue * ( kWhCost as BigDecimal)
def costDisplay = String.format(”%3.2f”,costDecimal)
sendEvent(name: “energyTwo”, value: “Cost\n$${costDisplay}”, unit: “”)
[name: “energy”, value: newValue, unit: “kWh”]
} else if (cmd.scale == 1) {
dispValue = String.format(”%5.2f”,newValue)+”\nkVAh"
[name: “energy”, value: newValue, unit: “kVAh”]
else if (cmd.scale==2) {
newValue = Math.round( cmd.scaledMeterValue ) // really not worth the hassle to show decimals for Watts
if (newValue != state.powerValue) {
dispValue = newValue+“w"
sendEvent(name: “powerDisp”, value: dispValue as String, unit: “”)
if (newValue < state.powerLow) {
dispValue = newValue+“w”+” on “+timeString
sendEvent(name: “powerOne”, value: dispValue as String, unit: “”)
state.powerLow = newValue
if (newValue > state.powerHigh) {
dispValue = newValue+“w”+” on "+timeString
sendEvent(name: “powerTwo”, value: dispValue as String, unit: “”)
state.powerHigh = newValue
state.powerValue = newValue
[name: “power”, value: newValue, unit: “W”]
def zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd) {
def map = [:]
map.name = "battery"
map.unit = "%"
if (cmd.batteryLevel == 0xFF) {
map.value = 1
map.descriptionText = "${device.displayName} has a low battery"
map.isStateChange = true
} else {
map.value = cmd.batteryLevel
// log.debug map
return map
// Handles all Z-Wave commands we aren’t interested in
log.debug “Unhandled event ${cmd}”
def refresh() {
delayBetween([
zwave.meterV2.meterGet(scale: 0).format(),
zwave.meterV2.meterGet(scale: 2).format()
def poll() {
refresh()
def reset() {
log.debug "${device.name} reset all values"
state.powerHigh = 0
state.powerLow = 99999
sendEvent(name: “energyOne”, value: “Since:\n”+timeString, unit: “”)
sendEvent(name: “powerOne”, value: “”, unit: “”)
sendEvent(name: “powerDisp”, value: “”, unit: “”)
sendEvent(name: “energyDisp”, value: “”, unit: “”)
sendEvent(name: “energyTwo”, value: “Cost\n–”, unit: “”)
sendEvent(name: “powerTwo”, value: “”, unit: “”)
// No V1 available
def cmd = delayBetween( [
zwave.meterV2.meterReset().format(),
cmd
def resetmaxmin() {
log.debug "${device.name} reset max/min values"
state.powerHigh = 0
refresh()
def configure() {
def cmd = delayBetween([
zwave.configurationV1.configurationSet(parameterNumber: 3, size: 1, scaledConfigurationValue: 0).format(), // Disable selective reporting, so always update based on schedule below <set to 1 to reduce network traffic>
zwave.configurationV1.configurationSet(parameterNumber: 4, size: 2, scaledConfigurationValue: 50).format(), // (DISABLED by first option) Don’t send unless watts have changed by 50
zwave.configurationV1.configurationSet(parameterNumber: 8, size: 1, scaledConfigurationValue: 10).format(), // (DISABLED by first option) Or by 10%
zwave.configurationV1.configurationSet(parameterNumber: 101, size: 4, scaledConfigurationValue: 6927).format(), // Combined energy in Watts
zwave.configurationV1.configurationSet(parameterNumber: 111, size: 4, scaledConfigurationValue: 30).format(), // Every 15 Seconds (for Watts)
zwave.configurationV1.configurationSet(parameterNumber: 102, size: 4, scaledConfigurationValue: 0).format(), // Combined energy in kWh
zwave.configurationV1.configurationSet(parameterNumber: 112, size: 4, scaledConfigurationValue: 60).format(), // every 60 seconds (for kWh)
zwave.configurationV1.configurationSet(parameterNumber: 103, size: 4, scaledConfigurationValue: 0).format(), // Disable report 3
zwave.configurationV1.configurationSet(parameterNumber: 113, size: 4, scaledConfigurationValue: 0).format() // Disable report 3
log.debug cmd
cmd
