I have the SmartThings classic app on an Android phone. I created an “automation” to turn on the switch (connected to a lamp) at sunset, it’s called “Eve LR Lite On”. I also have one that turns off the switch at a specific time. I also have an Amazon Alexa which is also connected to the SmartThings hub.
My problem is that the switch comes on correctly at sunset. However if I later turn off the switch either through the app or Alexa, for some reason it comes back on a few minutes later.
I checked to see if I had other automations that uses this switch but I don’t. I checked the Events List and I see only one activation of the automation.
How can I troubleshoot this problem further to find out what might be turning on the switch after I command it off.
