Automation to turn off device after elapsed time fails
@Lars
I use a Simulated Alexa Switch to start and stop activities on my Amazon Echos.
I set up an Automation in the ST App to turn off the switch after 2 hours.
It has worked fine for a long time but now the switch doesn’t turn off.
I also have one that turns off after one hour and it works.
If I shorten the time from 2 hours to 1 minute it works…
Not sure why this started recently…
I too have an automation to turn a switch off after 2 hours and it failed one day this week. Simply editing and saving the automation got it to fire
Pretty sure I tried that to no avail…
I decided to use Smart Lighting Power Allowance instead. Never had a problem with it failing.
We’re able to reproduce this issue and it is currently being investigated.
Thanks for the update @Brad_ST
Thanks for checking it out!
I am getting this issue also in the UK, some switches turn off some don’t
I also see this every day now for weeks, I had tried editing the automations and resaving them this worked on one of them for awhile but did nothing for another ones.
A fix for this was released in earlier this month. Are you still seeing this issue?
I just tried it for one hour and it worked as it should. Thanks for your help! :+1:
I am still having issues with virtual contact/switches in my alexa routine actually triggering the routine. Anyone else?
