TP-Link Tapo C310 Integration
Hello everyone, I would like to install an outdoor camera to integrate with smartthings, I saw the TP-Link Tapo C310 camera on amazon. I would like to know if it is compatible
Thanks so much
Not currently. If you would like that to integrate with SmartThings, then send an email to Tapo (TP-Link) to make an official integration.
Otherwise the Tapo cameras quite good and really cheap. I have a C100 and a C200. Both works well.
Tapo is now supported in the ST app.
When I tap the + then TP-link | Kasa smart, the type “Camera” doesn’t show up ?
Bulb ok, switch and dimmer only ?
Thank you
[EDIT : I got my answer]
Q1.7: Does Tapo camera work with SmartThings?
A: Nope, Tapo cameras are only compatible with Amazon Alexa and Google Home. Currently, there is no plan to add support for Samsung SmartThings or IFTTT.
You can use Kasa app. You need to install it ia Tapo all.
