Time based events failing?
Last week I learned a new ST lesson, that no matter how many backups you have, ST finds a way to fail them all, sooner or later (well, one failure was on me). So to turn my lights on at sunset, I have:
Rule Machine rule to turn on lights based on sun state - this one failed due to scheduler
IFTTT with virtual switch - as first back up - this one failed because IFTTT chanel was down
Rule Machine rule based on lux level -as second backup - this one failed because I forgot to change the batteries on my sensor
Sooo, I’ve added another: created a routine based on sun state. If all fail, at least I can have a button in the app (routine) to push to turn my lights on!
It’s a complete mess today for some reason. My devices weren’t reporting correctly in the app, I had to reboot the hub, and even after all of that, everything was hit or miss for about an hour where even my local devices (that are registered locally and execute commands locally and not through the cloud) were acting crazy. Then things started to come back and for now things seem to be OK but this is just crazy. I had to edit/rebuild all of my routines so they weren’t showing the next scheduled event in the past… this programming bug is just crazy to me. Why don’t they just flush these lingering ā€œnext eventā€ routines after 10min or something instead of just letting them sit there forever. Hell, I had routines that still would work occasionally when they were supposed to but they were showing as not having run in almost a week. I just don’t get it.
Complete mess here also. I went in the IDE to look at the scheduled event and discovered that most were scheduled in the past. So I went and edited (AGAIN!) all of my time based routine to force them to reschedule correctly. What is weird is that some of them were showing the correct time, let’s say 10 PM, in the first screen but when accessing the screen to edit the hour of execution, there it showed 1 hour earlier (9 PM in my example).
First time I notice this.
Two days in a row now and all my routines are scheduled properly. So…
I got to ask… Why is this problem so inconsistent? Why do some people have a ā€œcomplete messā€ and others are just fine? Give it 24 hours and the situation is likely to be reversed. I dont get it :frowning:
Same here, things are much, much better in the past few days. It baffles me why some of us suffer the problem while other don’t. Perhaps it is dependent on what servers people are assigned? Seems like every time a platform upgrade happens people may get shuffled around. Who knows? But for as long as it has been going on they sure don’t seem to have a REAL fix anytime soon.
I hear ya and after going through with reboots and editing all of my routines again like Kalto states; at least this morning things seemed to be working properly. I don’t get too excited when things start working again until it ā€œsticksā€ for a while… only time will tell. I just hate how it works for a while then goes to hell and then starts all over again.
After 3 days of scheduling bliss, my timed events are failing again. When will this madness end, when I unplug the system and pitch it in the garbage?
Reading the posts, some users are finding solutions to their issues.
I FOUND MINE! Life is now good!
I deleted all my Shortcuts.
See my post:
SOLVED - Gremlins & My Unstable ST Network
Well, I haven’t noticed any recent failures until today. My Gentle Wake Up light never ran this morning and my app that turns off my home theater system after an hour and a half of inactivity never fired. I woke up and my plasma TV and Xbox 360 had been on all night.
Recently, I have been getting failures of a different sort. According to the log, the scheduled routine triggers on time, reschedules the routine for the next day but it never actually turns on the devices. In one case I actually had to delete and recreate the routine before the devices turned on again.
For the past 4 days or so now, things seem to be working exactly how they are supposed to. Fingers crossed.
[quote=ā€œWA2FAST, post:1030, topic:26885, full:trueā€]
[/quote] Same here. Plus 20 characters
Agreed…the past 4 days have been working like they should. I was out of town last week and really hated that I didn’t have confidence in the status of my devices. I don’t want a system that I can’t rely on. But, the last few days, things are actually working great. Maybe they’ve found discovered the issue.
New problem for me today .light set to turn on when door
opens sunset to sunrise… never failed before. Now turning on in the middle of the day
I managed 4 days without any problems, but alas as of this morning almost a third of my scheduled events failed…
My lights at 10, 10:30 and 11PM all failed to turn off…
We’re any of these a ā€œdelayed offā€?
I’ve been having trouble since yesterday with lighting rules that have delay on or delay off in them.
The delay part of the rule is the only part that failed to work.
No delay… Simple rule that turns on light at Sunset and off at hh:mm PM
Every day some piece of this system is broken… POC can’t even get a simple command right, Turn off lights at 12:36. Using Smart lights to do it. turns of one light or the other when it does turn them off. App has gotten extremely slow and crashes more then ever. But hey the did solve the red banner warning. Wow
So when that happened to me, I logged into the IDE and realized that the failing events had the next scheduled event set to the past… so they were never going to actually execute. I was told to go into each routine all of the way to the end and then click ā€œDoneā€ to back your way out of each routine (routines that have schedules that are failing for you). This ā€œresetsā€ them and should solve the issue. I have had to do this numerous times over the past few months to address these issues but one thing I will say is after last weeks update, it seems to have ā€œstuckā€ so far and things are still working normally since then. Give it a shot again and see if that helps.
