This SmartApp can't be deleted at this time because it is installed by one or more users
Yes, there is no way to fix it at this point due to Google dropping the Nest API for integration for new integrations. Existing integrations are fine unless you disconnect and after that you are out of luck since you will not be able to reconnect now.
That sucks. Thanks for providing the information and link.
Thank you. Helped me 7/9/2020! Moving to new ST app and just didn’t use it need webcore and couldn’t figure out how to delete it. Thanks!
I’m having the same issue. I can’t get this uninstalled :frowning:
My problem was that i had mobile apps both android and ios in use, i removed ios, and was able to delete.
I’m pretty sure I’m doing this correctly. The current text is ā€œUninstallā€, not ā€œdeleteā€, yes? I’m in a crazy catch 22 trying to move my Hue lights from the V2 to the V3 hub. I can’t delete my old lights from the IDE, because WebCore uses them. I can’t delete WebCore because (I think) they reference my old lights. The WebCore engine won’t save my changes, so I can’t just delete the lights from the pistons. I’m hoping for an option that doesn’t include rebuiliding a home system with literally hundreds of lights, sensors, buttons, switches, etc.
Sorry, my post is almost 5 years old by now and I have not had that issue for a while. But I just checked and it says ā€œUninstall ā€œ for me. Good luck!
