This is probably covered somewhere here, but I can’t find it. How do you rename a location in the new app? I have re-named it in the IDE, but it still shows the old name in the new app.
If you go to Devices, choose Edit from the menu, you should be able to edit the name there. Before that make sure your home location is chosen instead of All Devices from the pull-down at the very top center of the header bar.
So I just changed my phone and the new App came pre-installed, so decided to give it a try before installing ST Classic.
So far not that bad, I do have several devices with custom device handlers, but most are switches/bulbs so I jsut created virtual devices and link these to the actual device through Smart Lightning, so a hassle but have all switches lights working.
I also changed a couple of Sylvania RGBW Bulbs I had back to default device handlers and these are recognized and work now (with added benefit that they run as local devices now), I also changed to the native Color Coordinator SmartApp and its working just fine.
I also created some virtual devices that pair to my Fan Speeds and light so that also working
Harmony App and activities are working
That only leaves me with a couple of custom devices that are not working on the App (Nest, RBoy Custom Lock DH). I will try to change Schlage lock back to native DH later
Almost all my SmartApps are there and work OK, CoRE and Action Tiles continue to work and can be accessed through new App. The only exception is Life360, I don’t see it in my list of SmartApps and presence is not updating in the new App (and get the Can’t connect in the presence cards)
At this point I think I’m going to stick with the New App and just find workarounds to the things not working.
So Life360 is there and I went through settings and all seems to be OK but the presence cards keep telling me “Can’t connect to device…” and they are not updating
Im ussig the default Zigbee RGBW bulb. Don’t know why but everytime I change something on the Zigbee network it becomes unstable for a while, but it’s working ok now
I also changed the lock to the default Z-Wave Lock (not the Z-Wave Lock with code, that one did not work) and lock is working on the new app as well, still using RBoys lock manager app
I have an IRIS keypad that I removed from my system to give to a friend. I removed it from the device list. Then I went thru the unpair proceedure, which seemed to work ok.
But in my things list there appeared a new IRIS keypad. Wondering why it got re-added. When looking at the instructions for the new app about adding devices it appears you don’t even have to go to the add screen it picks things up automatically. I didn’t have the app open. I wonder if this is what happened. If so, it’s something to watch out for. I guess one needs to either force stop the new app or take the device far away to reset it.
For the record, I’m not necessarily using the new app, but I have it on my phone and play around with it to see how it is working.
It doesn’t pick up zigbee devices like the Iris keypad automatically. It does pick up some LAN and WiFi devices automatically. But then the classic app picks up some LAN devices automatically as well.
According to the instructions in the new app it picks up things automatically and pops up a window asking if you want to add it. Now in theory you have to say yes to add it. The old app you had to put it in pairing mode first. That is what I was referring to.
In any event, it somehow got re-added without my consent. When it re-added it wasn’t under the same name I had before. It just come in as a Iris keypad.
According to the official knowledge base, it only does auto discovery for devices which do not require a hub, such a Samsung appliances or televisions.
Devices which do require a hub, which would include all zigbee devices, still have to have discovery started manually.
Well, I don’t know what is going on, but it still does the same thing. I delete it from ST in the app. I go to the IDE to check and it is gone. I do a reset on the keypad and the lights on the keypad indicate it is reset and back in pairing mode. I DONOT put either of the apps in pairing mode. When I go back in and look the keypad is back. So for some reason it is re-pairing whether I want it to or not.
I have done this 3 times with the same result. This is not necessarily a problem for me now as the keypad is going elsewhere and it will be away from my hub the next time I do it. But concerned something will pair when it isn’t supposed to.
At least the freaking mobile presence was working and it has gone for a toss as well. And well, looks like I will get the notification probably in 2019 to migrate.
