Thermostat and TRV (Radiator Valves)
Hi all,
Hoping to get a new boiler installed within the next few weeks and am hoping to have a smartthings / amazon echo compatible thermostat and radiator valves fitted at the same time.
Does anyone have any experience of the Nest thermostat versus any of the competition? I notice that some people are using the Netatmo Thermostat successfully but they have yet to release their TRVs.
From what I can see, the only working valves are the MiHome eTRVs unless someone knows any different?
Any wisdom gratefully received before I purchase the wrong kit.
I’m running evohome and controlling with echo via ifttt. There is supposed to be native control via amazon echo coming shortly and has been confirmed by a honeywell chap over on automatedhome.
Smartthings is apparently going to work with evohime, but it looks like it’s been “coming soon” for quite some time.
The echo to Netatmo integration should be happening in the next 7 days.
Thanks guys - sounds like things will be working with Echo before Smartthings unless there’s anything official in the pipeline?
Regarding the Netatmo - just noticed that there’s a deal on Amazon for the thermostat and a dot - does anyone know if the integration includes the Netatmo TRVs?
Thanks again
Looks as though the radiator valves are going to be released at some point.
Taken from Netatmo website.
ADDITIONAL SMART RADIATOR VALVE
Works only with the Netatmo Smart Thermostat or with the Netatmo Smart Radiator Valves Starter Pack
Sign up to receive an email when this product becomes available.
Good question. I will see if i can contact Netatmo again tomorrow and will ask the question. Unless anyone else knows the answer.
I see the TRVs are listed on the Maplin website but it also states that they only work with the Netatmo thermostat. From the reviews that I’ve read, it seems that the Netatmo thermostat is a little basic compared to the Nest which is a shame.
Can anyone confirm any radiator valves that work with the Nest and hopefully Smartthings or Echo?
The Danfoss TRVs are pretty great option
@Aaron when you say Danfoss TRV I’m assuming you mean the LC13. Are you guys working on adding this to the ST supported list?
Out of interest when you say they are a pretty good option os that based on the great work done by @richp @johnconstantelo and @AdamV in this thread?
Hi @brumster, My set up at home is Nest thermostat to control the boiler (advantages like auto away, friendly interface and self learning time schedule etc.) with my Danfoss LC13 TRV’s. The TRV’s each have their own time schedule set with a CoRE piston. So the radiators and boiler are are controlled independently. This works well on my system as I have a few radiators which do not have TRV’s. This is important as you need to make sure you have somewhere for the hot water to circulate.
Having used my Nest now for a few months i’m pleased with it and it is user friendly. It is also quite reliable. But I think I could probably achieve the same energy efficiency with a z-wave boiler switch and good time schedules set by CoRE. You could even use your presence as an auto away feature. It would take some thinking about, but it would probably be cheaper if perhaps not as reliable.
Thanks - I’ll look at the Danfoss LC13 TRV’s as well - I only intend on having a couple of them installed so that I can heat the bedroom in the morning and at night either on a schedule or manually set.
@richp I have an LC-13 working with your DH. Top job.
My question to Aaron was if and when are ST going to fully support it.
I use multiple Secure stats and switches to control the 3 zones in the house. The LC-13 compliments this by allowing me to time control rads that aren’t always in use. Nowhere near as intelligent as Nest but a lot cheaper (you can get the Secure stat and received for 30-40 quid on eBay).
Top work on the Danfoss DH. Much needed addition to the ST compatibility list (hopefully ST will add it at some point).
I contacted Netatmo about the radiator valve to Amazon echo integrations and they said:
We cannot tell you at the moment, but we are working on it anyway.
So there you go ! :confounded:
Good news on that front. I’m working with ST to get this certified following a prod from Danfoss. Process has only just started so I guess it will take a bit of time before its all official. :smiley:
Do you know what versions of FW it’s been confirmed working with?
Paul
I can’t see a F/W number but the docs that came with the TRV state S/W 1.01.
Thanks. I’ve got another post in your original danfoss thread. Curious to know if anyone has the older ones working.
Just noticed the Netatmo Smart Radiator Valves are now showing on the Maplin website for £59.99
They are not in stock yet, but I assume they will be shortly if they have listed them with a price.
I’m working on the Honeywell Evohome as we speak!
Sorry for the delay. It’s been on our plate for a while but we had some other major priorities come up.
We’re working on the Danfoss TRV as well, but that will likely be available after Evohome.
@csuk are you looking at a specific version or will you be looking to validate all versions as detailed here:
