Will SwitchBot and Shelly devices added by standard SmartThings integration work normally?
If they are listed as âPlaceholderâ in the IDE you are good to go.
hi ihave a SONOFF ZBMINI-L thats showing as a zigbee switch
landing light / ZigBee Switch /My home/ My home Hub / ONLINE / Local.
but not using an edge driver ?
Another way to verify any devices still needing moved from DTHs is to look in the IDE under âMy Hubsâ. The devices shown âattachedâ to a hub are still DTH based and have not yet been moved to an Edge based driver.
scroll down
thanks for that
History tells us things might not be what we had ever again, remember the posts
âonce we kill off the old app we can direct our resources into improving the new appâ
HmmâŠwe should remain hopefull but set our hopes lowâŠ
The problem with IFTTT, though, is that I think you need a subscription if you have more than maybe 3 free routinesâŠ
@rcbjr2 IFTTT Workaround: multiple IFTTT accounts. BTW I have 5 free routines somehow on each account
This isnât quite 100% accurate. It will show Groovy hub connected devices, but I donât think it will show Groovy cloud connected devices.
I just might be able to squeak by with that. One for when I leave and one for when top floor is vacant. I also have a routine that adjusts fan run time which I can lose is push came to shove.
I definitely want to do one for when I leave so I donât have to have another service checking location, but maybe I will just let ecobee try and run on its own to see how efficient it is with its built-in programming.
YetâŠ
Working out some capability issues with CO, and then Iâll work on switch, colorControl, and the dimmer capabilities (but that may take a while). Stay tuned.
Will there be absolutely any way to have Logitech Harmony Hubs work with ST after Sep 30th?
I have 2 harmony hubs as well.
Whatâs the Philips hue integration?
Iâm ios but I have android tablets scattered around the house so can use them too. Why do you ask?
Philips hue was just a response in the same post to another user but not related to harmony.
So Iâm out of luck then running 2 harmony hubs?
Never say never! It is always possible that one of the developers will figure out multiple Harmony bridges. You may want to post in the thread for the current edge driver for the one Harmony bridge and bring up the topic. They can definitely provide you with better details.
Perhaps not if you have 2 SmartThings hubs? Iâve no idea if that is the case
No way Iâm purchasing another hub for that.
Though I suspect this is just the start of things that arenât going to work for me anymore
True. Itâs a âpay-to-playâ system now. Only pre-made routines are free to users.
I really liked it but I didnât have many routines that used it and I didnât feel like spending 10s of hours looking to replace a routine I had lost just to discover said routine doesnât exists.
I get why they moved but their payment structure was just to high for the amount of use I would get so I left. Made similar routines and havenât looked back.
