If you’re looking for a cheap gateway so that you can more easily upgrade the firmware of Osram/Sylvania devices, here you go…
I’m not sure now if that gateway would provide a newer firmware than SmartThings does. Sylvania has retired the Lightify brand and their new Smart+ brand doesn’t work with the gateway.
I have some Gardenspots that are still on an older firmware and Smartthings says that it is the latest even though I have other Gardenspots that are on a newer firmware. I’m hoping that the Lightiy Gateway might show differently. Anyway, it was cheap enough to try.
I don’t think that is true.
https://www.smartplus.community/t/controlling-your-lights-with-the-osram-lightify-gateway/77
Interesting! Thought I had read otherwise somewhere.
As I suspected, with the hub, it saw that my Gardenspots were on the old firmware and I was able to update it. I don’t know why SmartThing OTA says that it was on the latest firmware when it obviously isn’t.
Probably is the latest firmware Sylvania has submitted to Samsung.
