Hello I originally purchased 4 Osram Lightify RGBW Lightify Led RT 5/6 bulbs. I had an issue where one of the bulbs got stuck in yellow color mode. I did an RMA to Sylvania/OSRAM and they sent out a new one. The question I have is that the new bulb is detected as Sylvania SMART RT5/6 not the OSRAM LED RT5/6.
Is this a problem? Will they be handled differently by smart things apps or automation.
Sylvania bought OSRAM. The bulbs are the same. You probably have a new firmware version that IDs the bulb as “Sylvania”. I believe it is just a label and the device should control successfully.
