I recently added the Sylvania/Osram A19 dimmable white bulb to ST App on iPhone. I then tried to have Alexa find the lamp. I have this set up with two other A19 bulbs and Alexa. Alexa never discovered third lamp. I removed it from ST App. Now I cannot re-connect that bulb with ST app. I have hard reset the bulb successfully several times, but it still is not discoverable.
Shouldn’t this bulb be found natively by ST app under Add a Thing? Even if I try to Add Device Manually it cannot be found
