gyzmo
1
Is there a way to switch the hub v3 from ethernet to wifi without loosing all my configurations?
I went to the process « add a device, choose the v3 hub and I stopped at choose between wifi or ethernet…I was scared to loose all my configs.
Thank you!
Go to settings > update wi-fi information and see if it lets you do it that way. Not sure if that works without it initially setup or not.
Rizlah
(Neil Cameron)
3
I just switched between the two by plugging and unplugging the cable after I set the Wi-Fi up.
I did have Wi-Fi setup first though. Not sure if that makes a difference.
