Switch Smartthings Hub from Wifi to Ethernet?
I read on another post about switching from Ethernet to Wifi, but how do I switch from Wifi to Ethernet? Is there any way without completely resetting? I keep getting a server error and the damn thing is never connected. I am hoping switching to Ethernet will help that issue.
You should be able to just connect the hub via ethernet and it will prioritize the ethernet connection.
Is there a way to tell if its connected via wifi or ethernet? As it is now, the hub frequently disconnects from my network even though the network is stable. That’s why I thought it was the wifi signal. If it was plugged via ethernet, it should stay connected, right?
Were you possibly impacted by the outage this morning?
https://status.smartthings.com/incidents/d4pqd1ffd2bx
same issue here. is there a solution?
