This worked but it took about 40 seconds on the last step to go from flashing blue to solid blue and about 15 seconds to go from solid blue to green. So give it time.
thank you so much it worked for me.
Thanks, Edwin this really worked fine.
Thank you.
This also worked for me just now.
As someone else has mentioned, patience is important with this task. Certain steps took longer than the what’s mentioned in this post. But tried a few variations of this, mixing up the order of the tasks, and did the job, just took a lot longer, so don’t loose hope!
Reviving this thread. The instructions are not working for me. I followed Edwin’s instructions mulitple times to no avail. Need to be able to switch to Wifi as we will be using Starlink exclusively and it does not have ethernet ports, nor are we wanting to purchase the adapter.
Is there a way to accomplish this in 2024 without jumping through these hoops?
Which hub do you have?
IM6001 -V3P01
Looks to be the 3rd generation
A post was merged into an existing topic: Another Smart Hub Connection Issue - Error code 33-504
