Sunset and Sunrise Times
Does anyone know how to fix the following …
Although my geographic coordinates are correct (Southern England) the times for sunset and sunrise
are set as follows
Coordinates 50.95827103 N, 0.14135577 W
Time Zone Europe/London
Weather
Sunrise 08:02
Sunset15:57
and Default Location is greyed out and set as “True”.
You might try changing your location to another timezones and then changing it back to the correct location and see if that fixes it.
If it does not, you will probably need to contact SmartThings support.
Thanks for your prompt reply. Will give that a try
