Hi, When I look at “Home” on the SmartThings desktop web thingy (can’t think off the name). It says location Europe/London, Weather and gives a sunrise and sunset time. The Sunset time is 20.43 which is a long way off what it should be at 18.48. I can’t find anywhere to change this.
The problem being none of my lights etc are activating at the correct time.
I have looked everywhere in browser app and also the Android app which I use to set it all up and can’t find anywhere to change the time.
As it says Europe/London for time zone that should be all but it’s not.
Any ideas?
Are you logging into the correct shard?
I’ve just checked mine and I’m uk with sunset at 6.41.
Log.into here
https://graph-eu01-euwest1.api.smartthings.com
Hi, I just followed your link and the sset srise is exactly the same.
In Co-ordinates it is 51.41162 N, 3.4733243 W which is within a few hundred yards.
Whenever I use the “Smartlighting” part of automation I have to set the -+ 100mins or more in advance to get it to come on using ST motion sensor. Unless it’s the sensor that’s out. I will look at that next.
P.S. nothing to change in motion sensor.
On your SmartThings app press the tab button top left so the menu pops out.
And then you should have a cog click that and check the location it’s set right in there.
That’s if your android like me it should be similar on iOS
Hi, I just did that and then closed browser, reopened and it is still the same.
As it says weather, where is it getting this information from? I don’t recall any weather app anywhere.
I can’t add a screen grab, there doesn’t seem to be option to add a photo.
Hi again, all the logs I am looking at are the correct time as I look at live logging.
You have changed the location on the SmartThings app haven’t you like I said not the browser?
Yeah possibly I can’t remember now lol
I have read about this before and it was something simple but can’t think of it now
Hi, I just found a post with the same problem. It seems that because it’s a USA server it’s causing problems. SmartThings recommend adding 60 mins to everything. LOL That’ll fix it. Seems lots of USA have same problem due to their own time regions.
It goes back in 3 weeks so it should work as normal after that.
The post I found was from 2015, I would have thought they would have solved it by now.
Does this help.
Hi Bob, already tried that Still the same. When I look at live logging it shows the correct time (to the second). When I look at the (screen shot) above everything is showing 1 hour behind. As in Last activity, Last ping etc…
All the times shown there are 1 hour behind the the actual live log time.
I have just deleted all my LIFX/ST timed switches and started from scratch. It is sunset in about 13 mins so lets see what happens.
Nothing turned on at Sunset. So I then did the motion sensor light to Sunset -60 = nothing.
Sunset -90 = nothing.
Sunset -120 = yes it works by advancing 120 mins before sunset.
When I look at the “recent” tab for the light it shows turned on at 18-55 which is correct. But not at 18-53 when set at -60 mins before sunset, or at 18-54 when it was set at -90 mins before sunset.
So somewhere it is losing 115 mins, so nothing to do with BST.
When I put the Co-ordinates in first screen shot into Google maps, it is no more than 30 feet out. So it is not that.
Can anyone tell me where the “Weather” part of screen shot one is located either in the app or the web browser?
I’m in UK as well.
This is what my hub is showing.
Have you tried a reboot of the hub to see what happens.
Or maybe a power down / up. Make sure you remove the batteries as well. (If fitted).
Looking at your times you must be over towards the east coast. I am S. Wales so difference is about 18 mins.
Yes. Near Cambridge.
Just found it Milton, so yes I am 227 west to you. So 18 mins.
It doesn’t make sense to be 115 mins out. That would put me in the middle of the Atlantic.
