mathewss
(Sean Mathews)
August 19, 2021, 8:32pm
1
When I adopt my device under My Testing devices everything works up to the last screen where it said it was successful and has an “Done” button on the bottom. When I press done it crashes and the device is never added
I tried uninstalling but that did not seem to work so I am starting to think the issue is in my account itself?
suggestions and ideas appreciated.
Best
SM
nayelyz
(SmartThings Developer Support)
August 19, 2021, 9:51pm
2
Hello, @mathewss ! Can you provide more details, please?
What kind of device are you trying to integrate? (cloud-connected, hub-connected > Zigbee, Z-Wave)
Is it a custom handler you made? If so, please share its configuration (in the Developer Workspace and source-code if possible)
mathewss
(Sean Mathews)
August 19, 2021, 10:14pm
3
It is a direct connected device using:
GitHub - SmartThingsCommunity/st-device-sdk-c-ref: SmartThings SDK Reference for Direct Connected Devi
The project and firmware are here.
GitHub - nutechsoftware/AlarmDecoder-IoT: AlarmDecoder Internet Of Things
Others have used this firmware recently and have successfully adopted so again it seems like the problem is on my profile.
Best
SM
mathewss
(Sean Mathews)
August 19, 2021, 10:32pm
4
Just noticed I had an update available for the App. I was running 1.7.67.29.
I ran the update and now I am on 1.7.69.23
I will keep kicking it see if I can get this working again.
Now it does not start adopting before it shows this error
nayelyz
August 19, 2021, 10:35pm
5
I see…just to discard possibilities.
Make sure you’re using the last published version of the ST mobile app. (I see you already checked that)
Also, to avoid any cache issues in Android devices, you can go to the mobile device settings > apps > SmartThings App > storage > clear cache
If you already verified that, please send us an email to build@smartthings.com with your Onboarding_config.json file.
mathewss
(Sean Mathews)
August 19, 2021, 10:52pm
6
Yep tried clearing cache same error.
Email sent.
