I have a Zooz 4-in-1 Sensor, ever since the new release of the SmartTings android app (1.7.27-25) every time I attempt to access the sensor the app will soft crash and restart. When creating new automations the automations will not fire.
From the online sensor view i can confirm the sensor is working correctly.
Troubleshooting steps:
I used the Zooz provided device handler, and also attempted to use a generic Z-wave motion device handler. This resulted in the same broken behavior.
The old app works without issue
Attempted to reset the sensor and remove it from the hub. This resulted in the same broken behavior.
Remove the automation and create new ones. Resulted in the same broken behavior.
Any one else seeing this? It’s got to be related to the new app.
I have not made this DTH update and I am not crashing. I am on iOS, same as Jimmy so it does appear to be Android only. As I said, follow the above for a fix.
