This may seem very strange, or may be a known issue. I’m not sure which…
I create a simple on/off routine triggered by a switch turning on. Nothing more to it than that.
It’s off the same switch basically to turn itself back on as soon as turned off…
Switch A turns ON when switch A is turned OFF
This works normally as it should. No issues.
The problem is when I try to restrict it by modes.
I have 6 modes. One (default most of the time) is “daytime”
I can select all the mode check boxes except daytime. It won’t put a visible checkbox on daytime. But if I select next, you will see daytime listed in modes selected. Save it and come back into, and poof, daytime is gone.
Explain this…
