This app seems a little wonky - Why does the ‘change mode to’ option not populate with a drop down list of all the modes you’ve already made? Having to type it in again seems silly. Also, in the list of smart apps, there should should be a differentiator for smart apps for ones that are running all the time (like this one)and ones that are have to be triggered (i.e, turn on light) - maybe a glowing green dot for ones that are ‘active’ ? I don’t know… then maybe you could suspend them temporarily if you wanted to?
And speaking of typing it in again, apparently I used that sunrise/sunset app but put in ‘day’ instead of ‘Day’ when I added the new mode in the list of modes, so I got a push notification that it tried to change to mode ‘Day’. This is almost user-hostile behavior.
Never thought about capitalization being a factor. Will have to check on that when I get home. However it magically started working last night. Sense am going to be getting home so late to night…will try it again.
